Old 10-10-2006, 16:34
Angry Rear brakes!
Right, after installing the lowering springs in my S12 my rear brakes seem to be locking on a tad.
I got it back up in the air and checked all the hoses and cables and they seemed fine. The hand brake still has a healthy amount of travel in it and the actuator leavers on the callipers can be freely 'wiggled' when not under load.
The issue is compounded by the near side disc which appears to be warped (wheel will rotate relatively freely for about 1/2 of a turn then locks quite tight for the last 1/2) however the offside seems to just be binding all the time.
Any ideas before I take the callipers off and ruin them further by trying to "service" them?
Old 11-10-2006, 19:38
hey i seem to be having the same problem that when i am driving slow or reversing there is a nasty binding noise from the rear left and cant for the life of me work out why...... i also have gas shocks on the rear with 35mm lower springs???????
Old 11-10-2006, 20:01
i have gas shox and lowering springs, but no probs.
Old 11-10-2006, 21:18
Could be a partial siezed caliper or just cack on the pads. The astras I drive at work do the same thing in reverse!
Old 11-10-2006, 21:39
both of my rear calapers have been un seized amd rebuilt
Old 11-10-2006, 22:30
i have that noise too
i have ordered new pad anti noise shims, the little springs each side of the pads.
Old 11-10-2006, 23:29
The brakes are def hanging on! I've got to replace the disks all round anyway so I guess I'll just have the whole lot apart while i'm there.
Just wanted to know if there was a known issue i'd over looked just incase I did all the work and ended up with the same problem
Old 14-10-2006, 11:15
where did you order the anti noise shims??
