Old 11-11-2006, 12:15
s12Rob's Avatar
s12Rob s12Rob is offline
Default misfire
ryte ive had this misfire on mine for a while. i think adz willl know what im on about, ive done dissy cap, rotar arm, plugs and leads and is still the same.
any ideas????
Old 12-11-2006, 21:34
When is it misfiring, on idle, whilst driving or both? You need to add a little more detail if you want peoples advice.
Old 12-11-2006, 22:03
Yup agreed. For example,misfiring on boost can be totally different problem to at idle
Old 13-11-2006, 17:35
s12Rob's Avatar
well its on idle or when i rev is at a constant speed u can hear it missing
Old 13-11-2006, 17:44
That would normally mean that its either the following
Blown head gasket
bad injector or injector electrics( First thing is to check that you havnt knocked a plug slightly off the injector itself)
Bad ht leads, either old or damaged or poor contacts
Damaged/mispaced/faulty spark plugs.
Do a compression test aswell next after you have ruled out all the above.
Old 13-11-2006, 23:56
Excite Excite is offline
Excite is an unknown quantity at this point
mines the same mate and my engine is sweet as as its been looked at. its been there since i have had it and the engine has only covered 60k.... really weird, i have changed the same as you also the distributor. my mechanic mate whos very good says its something to do with hot or cold plugs and how quick they burn off fuel.
im gonna take mine to norris designs i think and get a few more bhp and a good set up????
IM OFF LINE FOR A WHILE SORTING OUT NEW CAR/HOUSE/JOB
IM BUSY AS F**K
Old 14-11-2006, 00:00
Excite - I saw your car down at Ace Cafe last week. I wouldn't take your car to Norris unless you have a few thousand pounds spare
Old 14-11-2006, 03:14
What plugs are you using ?
Old 14-11-2006, 03:27
30psi you should of come say hi
Adz:
plugs are ngk-r mate, gonna take a trip to nissan garage and see what they suggest?
IM BUSY AS F**K
Old 14-11-2006, 03:31
You should be using ngk bcpr7es and regap them to 0.9mm
