Old 11-11-2006, 12:54
boosted boosted is offline
boosted is an unknown quantity at this point
Default Question time!!
1.Safe Boost increase on std t2 turbo? (fueling std etc). Will be fitting colder plugs.
2.Not keen on bleed valve when i did my s14 i fitted an adjustable actuator, i still have original from s14 and can make this adjustable, is this the way to go?
3. Bought a large calibra turbo intercooler on ebay for a quid so no worries with this! engine driven fan removed. Have electric fan and cowling to fit to rad.
4. Is the wheel stud pattern 4 X 114?
5. Availbilty of lowering springs and or dampers.
6.Running side exit with just middle box. Still well below track db limits. Any other options?
7 Any other concerns/ info?
8. Where can i get rear spoiler as mine missing from my car?
(have read all of how to section).
Many thanks for help
BOOSTED
Old 11-11-2006, 14:18
1.with cooler fitted 12-14psi depending on turbo cond.
2.yep or ball and spring boost controller
3.
4. 4x114.3 i think?
5. avo do the springs and i kyb do gas shocks
6.big 2.5" system with only rear box
7.yep
8.dunno
Old 11-11-2006, 18:27
Dan Dan is offline
silviagod sometimes makes fibreglass replacements for the standard spoiler: http://www.silviagod.pwp.blueyonder....Fibreglass.htm
otherwise you can use one from a nissan primera, rover 220 i think, or maybe an audi 80..
