Old 15-11-2006, 00:23
Beany-s12's Avatar
Default s13 bits
hi i'm on my 3rd s12 now and thought it was about time i played with it as my last 2 were pretty much standard! its came with a cossy inter cooler, lightened and balanced flywheel, k&n cone filter and uprated brake discs and has been converted from auto to manual! i've bought an s13 for spares and have already fitted the turbo air flow meter and stainless rear exhaust section and removed the centre box!
gonna fit the s13 gearbox soon and was wondering if there is any thing i need to know before stripping mine out as its in daily use and also if there are any other parts i can use off the s13 that might improve my old s12!
Old 15-11-2006, 01:43
Welcome to the site
The air flow meters for the s12 and s13 are both the same as far as i know and im curious as to why you want to fit the s13 gearbox? The s12 gearbox is fine for 250 bhp easily and very durable in my experinece as ive not experienced any problems as of yet.
The s13 diff can be made to fit by using parts from both diffs.
A good move if you have an s13 is to fit the ca18det from it as it is a good base for big power and has alot more off the shelf mods available for it.
Old 15-11-2006, 19:19
Beany-s12's Avatar
changing gearbox cause mine is noisey in 2nd and thought if the s13 fits might aswell use it! can't use engine though as the car came with no head and a blown bottom end!
