Old 16-12-2006, 22:08
Default S12 pulling a 'wheelie' on the strip
http://www.youtube.com/watch?v=pQjoHtq_06c
hehe.
Old 16-12-2006, 22:27
is that ben diggles from fj.com
Old 17-12-2006, 12:43
no idea
Old 17-12-2006, 13:30
yep its ben, i emailed him last nite and he sent me the same vid through.
Old 18-12-2006, 01:06
Yeah there's only 1 S12 that can do that and it belongs to Mr Ben Diggles
Old 18-12-2006, 08:04
at the moment , he's not even had much headwork or wild cams in his motor, just a regrind from kelford cams.
Old 18-12-2006, 10:39
You'll have to do some good work to the rear end to get it to not induce much camber if you want to get good grip like that. Oh, and some Hoosiers will help as well
Old 18-12-2006, 14:01
no worries martin, i'am spending loads on it and if it needs hoosiers, then it will get them.
Old 18-12-2006, 14:03
Might be worth thinking about using a Ford 9" locker if money is no object
Old 18-12-2006, 14:13
i dont think i'll be going to that extreme, but ben only uses a z31 diff set up with strengthened shafts, i'am trying to use more or less his set up ie:rb25 box, quatermaster twin plate clutch and nismo flywheel, i've payed for the cams today, they were ordered last night.
