Old 04-01-2007, 18:41
burnings12 burnings12 is offline
S12oc Newbie
burnings12 is an unknown quantity at this point
Default Noise of belt on my s12.
Hello! veiled I have a noise of belt on my s12 and I wanted to know if that could announce something or if it is simply because of moisture/wear of the pulley and which A 150.000 km? Also, it is enough bizzare bus has the stop with the idle, I increase power ya no whistle, I put my heating (bottom has because the other position does not function any more for the moment) and he whistles with least acceleration? and the other thing as it is as Ca does not do it everytime has days there or I do not have any noise and I think that is to bind has the humiditer? say to me what you think please I would like to know if Ca can come from of a bearing use who would block? (ha yes the noise vien of the belt connecting alternator and pump water?) THANK YOU, Sorry i'am french
Old 04-01-2007, 19:43
first of all welcome to S12oc,
you english is a little hard to understand, but i think i get the idea, sounds like you have the fan belt squeeling, you need to tighten or replace it, to tighten it you need to losen the top bolt of the alternator/generator and pull it out a bit till the belt goes tight.
i hope you can understand this, if not i know a few on here can speak french and can relpy with a good translate.
let us know how you get on with it.
Old 04-01-2007, 20:02
S12oc Newbie
Smile
hi ! ok thank you, I will test!
