Old 13-01-2007, 01:32
Default ca gearbox ratios
what are the gear ratios for the et ca s12 and s13 gearboxes? are they in the manual?
Also does the s13 use a different size diff to the s12?
Old 13-01-2007, 04:28
Magnum's Avatar
Magnum Magnum is offline
84-86 S12
1st 3.592:1
2nd 2.057:1
3rd 1.361:1
4th 1.000.:1
5th 0.821:1
Rev 3.657:1
86.5+ S12
FS5W71C Warner
1st 3.321:1
2nd 1.902:1
3rd 1.308:1
4th 1:000:1
5th 0.759:1
Rev 3.382:1
Old 13-01-2007, 09:33
are they both ca18et S12 gearbox's, 1 which is mk1 and the other mk2?
Old 13-01-2007, 12:15
the fj box also has a different ratio, i think shorter first 2 gears and a longer final drive
Old 13-01-2007, 12:21
whats the diff ratio? prob 3.92
Old 13-01-2007, 12:23
what, on the fj dave.
Old 13-01-2007, 12:34
with it being an NA engine and a sporty car i would say 3.9 / 4.1
the lower the ratio (diff) the longer the gear
Old 13-01-2007, 15:55
Magnum's Avatar
the first one is the MK1 and the second one is the MK2 tranny.
Old 14-01-2007, 00:24
You cant use the S13 crown wheel/pinion in the s12 case.
Old 14-01-2007, 00:28
are you a vampire mart ?
