Old 25-01-2007, 22:22
Default headbolts
has anyone found a reasonably priced supplier for ET headbolts? nissan is nearly £50, found them for $46 plus shipping but probably get stung for import too. anything in the uk?
Old 26-01-2007, 02:03
Whats wrong with £46 from nissan
Old 26-01-2007, 03:34
i don't know but i've got to buy some more engine mounts, to put the fj in, i think i've done my self wrong gettin rid off my old ones ,as i have to buy the same ones again, and never got payed for the last ones .
Old 26-01-2007, 09:16
If you have access to a machine shop I'd get the existing threads re drilled and tapped to M11, and then you could use the thicker S13 bolts. You need an SR20 bolt for the long one.
But in answer to your question, I don't know.
Old 26-01-2007, 09:52
which mounts shaun,the metal brackets or actual rubbers?i bet they are totally different to et ones as well?i could of dug some out for ya otherwise
Old 26-01-2007, 10:18
s12Rob's Avatar
s12Rob s12Rob is offline
you dont need to change the head bolts, they are not stretch bolts.
Old 26-01-2007, 10:19
If they have been used in the past and some monkey has over tightened them beyond there yield, then the only safe way is to use new ones.
Old 26-01-2007, 10:27
naah mike its the actual rubber ones, i've got some std s12 ca ones, the fj ones are just a block of rubber, with threaded bar each side, i do have some spares somewhere, but i can't seem to find them yet.
i replace em every time
Old 26-01-2007, 12:55
s12Rob's Avatar
oh yeah i agree to use new ones everytime but u can use them again
