Old 20-02-2007, 11:40
James H's Avatar
James H James H is offline
Default Lsd...
Can a lsd for the s12 be easly swapped into another s12, also would it make any difference if the lsd was of a mk1 & going onto a mk2?
Thanks James
Old 20-02-2007, 11:48
The S12 didn't come with an LSD. Do you know what type you have? Is it the S13 vLSD conversion or do you have a proper KAAZ/Nismo setup?
I'm guessing that it's the former and if that's the case then you'd need to swap both the diff housing and the O/S drive shaft + Inner shaft to transplant it. AFAIK the rear subframe is the same for the MK1 and MK2.
