Old 27-02-2007, 07:42
Default wheel spacers for the rear?
does anyone know what would be the biggest size wheel spacers i could fit on the rear with 7 inch width rims? taken the whole units apart on mine and looking to get 25mm spacers like the front but dont know whether it will foul the arch????
Old 27-02-2007, 09:26
Depends soley on the offset of the wheel...
Old 27-02-2007, 10:01
RichardK's Avatar
RichardK RichardK is offline
Forum Administrator
I have 25mm spacers on the rear with 215x35x18 and it's spot on
Old 27-02-2007, 10:03
Yeh but if they're 15 offset wheels for example they are gonna be damn close as it is.
We need to know the offset
Old 27-02-2007, 10:06
RichardK's Avatar
Forum Administrator
Oh yeah forgot to mention they are 38 offset
Old 27-02-2007, 17:35
yea they are et 45
Old 27-02-2007, 20:20
Well you could probably use up to 25mm spacers. Best see how much clearance you have, as camber will effect the clearance
Old 27-02-2007, 23:22
yea i have a set of h&r hubcentric wheel spacers that bolt on and have 4 studs off them, while i have the rear hubs apart i need to work out if should get longer wheel studs or the same set of spacers as the front>???
Old 28-02-2007, 10:14
RichardK's Avatar
Forum Administrator
I have longer studs on mine.
Very glad I bought these as they have loads of thread where as the standard ones are very short.
Old 28-02-2007, 21:57
im after some if you have 2 going spare
