Old 09-03-2007, 23:37
Default Lightweight starter alternative
Me and Adz discovered yesterday that the s13 ca18det starter motor fits the s12 and is smaller and lighter. Im now using one rather than my old s12 one.
Old 10-03-2007, 00:39
Yeah its almost essential I found to use one anyway on a DET, coz the starter touches a water pipe really hard, it breaks, leaks, and you get annoyed at the car
Old 10-03-2007, 00:48
the should match the starter to the flywheel, the ring gear on the ET and DET flywheels is slightly different
Old 10-03-2007, 02:11
Found this out when trying trying to refit the s12 starter that pukka used on his old det
Any ideas as to why it fitted on his old engine but not this one? Are the det`s different around that area in some way, such as that hard water pipe you mentioed?
Old 10-03-2007, 07:39
ChEsTeR ChEsTeR is offline
I dont think so. I used s12 starter with a DET flywell. I had to because i used DET cranck on ET engine and everything worked just fine.
Old 10-03-2007, 11:23
Yeh so do I, but maybe they're only slightly different as he suggests.
Its probably down to how the gear box bolts to the engine, ie slightly play and also general tolerances, will make it different each time
Old 12-03-2007, 19:03
water pipe outlets from the block are different on jap and UK DETs
Old 12-03-2007, 20:13
So what det have i got now?. I could use my s12 starter before but it was impossable with this one. Are there any other differences?
Old 12-03-2007, 20:21
don't know, never tried to fit an s12 starter to a DET. likely you had a jap engine before and a UK one now
Old 12-03-2007, 20:55
I found it near impossible to fit the bolts into the motor, the reason being is biting the pipe. A quick angle grind sorted that out though
