Old 19-03-2007, 19:12
s12Rob's Avatar
s12Rob s12Rob is offline
Default s13 short shifter
will these go on the mk2 s12 box?
Old 19-03-2007, 20:01
i think the s13 one fits, i think 30psi may know, cos i think its bin mentioned b4.
Old 19-03-2007, 20:50
Magoo Magoo is offline
Smile
I bought one off ebay for an s13, 5 bolts are exactly the same, I had to drill the larger bolt hole on the left hand side as you look at it.
Also had to relieve some alloy from top and bottom as once it was bolted in it wouldn't engage the gears fully.
I messed about fitting and taking it off again until I had relieved the desired amount to engage all gears then bolted it back in place, bit of a pain in the arse but nothing too hard about it.
Does make a big difference over the standard MK2 stick
Old 20-03-2007, 00:50
The 2 moon shaped style ones work well. Just use the original bush that goes on the end of the shifter
