Old 26-03-2007, 12:52
Default Boost and Intercooler?
We finnally got round to putting an intercooler on the 12 at the weekend but the boost seems to have dropped to 10psi from 12psi at the inlet manifold, is that because of the intercooler or is it because I'm a muppet and didn't tighten a hose properly?
P.S. Still running a T2
Old 26-03-2007, 13:11
what i/c are you using mate, and have you checked the boost b4 the i/c ? .
Old 26-03-2007, 13:25
What spark plugs do you have?
What timing do you set?
Old 26-03-2007, 13:27
It's the one Adz had before he went all Bling Bling
We haven't done any testing yet as Slimreaper only found out that it was doing last night after driving it home from getting it fitted. Just wondered if there was a straight forward explanation for it due to the higher volume of air in the inlet system or summat.
The only other thing I can think of that's changed is the turbo inlet pipe is now very slightly (and I mean very slightly) pinched between the hot and cold pipe of the IC.
Old 26-03-2007, 13:28
We haven't changed either.
Old 26-03-2007, 14:21
Pressure drops are common across intercoolers, due to resistance in the intercooler and pipe work.
Old 26-03-2007, 14:34
I see, that makes sense, Is 2psi a lot to drop or not?
This kinda leads me on to my next question which is where should I be reading my bosst pressure from? I just tapped a new guage into the the pipe that the Factory fitted boost guage ran from, but If I'm lossing pressure through the IC then should I read it from the turbo side to make sure I don't over work that?
Old 26-03-2007, 14:39
The actuator should be fed off of the compressor housing of the turbo.
Its probably an average drop for the cheaper type of IC's, but remember that its only a T2 trying to push the air through.
Old 26-03-2007, 14:45
The actuator is fed from the compressor housing but is that where I should also read the boost from?
Old 26-03-2007, 14:51
I see what you mean now...
I think it would make more sense to read it at the inlet manifold. That way you can monitor leaks etc.
Wouldn't turn it past 12psi though...
