Old 30-04-2007, 22:53
graememk graememk is offline
Default silvia s12et injectors
what flow rate are the standard injectors please?
what psi should i expect the silvia pump to deliver?
what pressure should the rail be at idle?
many thanks
graeme
Old 30-04-2007, 23:23
270cc.
Approx 35psi with zero vacuum, so therefore approx 30psi at idle
Old 30-04-2007, 23:32
many thanks
very helpfull
Old 30-04-2007, 23:43
ChEsTeR ChEsTeR is offline
But if the punp gives a requested preasure ai idle id does not meen that it will give the same at full boost and 6K rpm. U should chcek during accelaration if the preasure is not falling.
