Old 07-05-2007, 18:08
MrDan MrDan is offline
S12oc Newbie
MrDan is an unknown quantity at this point
Default My S12 full white RS-X
Don't really know much about where to put pics up so i thought here would be ok!
Plus i have a few little problems so i thought someone would be able to help.
Here she is.
Problem is the car has some flat spots, i put some new plugs in and it helped, but it's only an intermitent problem, sometimes it goes very well and other times it's really flat, sort of on/off/on/off power!
Someone help! cheers Oh and it has a CA18 DET engine in.
Dan.
Old 08-05-2007, 05:17
check the fault codes on the ECU to help but maybe the ignition coils (one for each plug) are intermittent
Old 08-05-2007, 13:46
Does it do when it's hot and when it does it is it running on three cylinders?
If so it could be a coil pack on the way out as they tend to sot working when hot before failing all together.
