Old 14-05-2007, 17:24
s12Rob's Avatar
s12Rob s12Rob is offline
Default What sort of power could i achieve with this lot
det block
ported et head
poerted et inlet
t3 turbo (18 psi boost)
volvo 940 front mount
s13 injectors
apexi afc
walbro255
260 bit optimistic
Old 14-05-2007, 17:27
Exhaust?
Old 14-05-2007, 17:31
s12Rob's Avatar
sorry 2.5" straight through with center silencer side exit
Old 14-05-2007, 17:33
Get a piper cam in there as well.
Old 14-05-2007, 17:43
s12Rob's Avatar
cant find one anywhere bud
Old 14-05-2007, 17:46
Have you changed the clutch?
Piper still do them iirc or alternatively use the Autosprint cam
Old 14-05-2007, 17:59
s12Rob's Avatar
i will be putting in a s1 uprated clutch to go with my s13 box
Old 14-05-2007, 18:20
Piper still regrind them. You need to send them your old cam.
Some don't recommend the cam, but on my setup it was good. Max power at 6.1K, it was pretty manic at the top end.
Old 14-05-2007, 18:29
The power you could expect would depend on who puts it together and sets it all up. 260hp would be about right on a spot on setup with good fueling but afc isnt the best and it still retains the afm. I expect that you will end up with about 245-250
edit im basing on you using the piper cam as its most beneficial with larger turbos
