Old 15-05-2007, 23:53
eurolightning eurolightning is offline
eurolightning is an unknown quantity at this point
Default head gasket
Hi ok so what the pit falls to look out for when changing the head gasket on a Mk11
and what sort of a job is it 1--10 how hard
Old 16-05-2007, 00:33
ChEsTeR ChEsTeR is offline
First time 10.
Last time 1
Old 16-05-2007, 09:29
Just make sure you have it skimmed and both surfaces are immaculate before you assemble. The rest if fairly nuts and bolts stuff. A nice "clean as possible" environment always helps. Make sure you use the correct torque settings (I have a Nissan workshop manual so can look them up if you need, someone will probably geek out and tell you what they are off the top of their head though! )
Most head's should be torqued down in a certain order (middle out I think ) But if you take your time then it should cause you no massive hardships!
Have you found a car then? or just checking one out?
Old 16-05-2007, 12:46
54-61ft/lbs lol.
Old 16-05-2007, 14:55
Lol, I knew it!!!
Old 16-05-2007, 19:57
Default great
thanks guys thats been helpful i have been looking at the s12 moded in to the pick up thats in the sale section what you lot think ?
I also got all my fingers crossed that docwra will come back to me (couple of people beat me to the punch) they might not come up with the goods though
