Old 11-06-2007, 22:04
rob turbo's Avatar
Default boost
what would ya say would be a safe psi for standard pistons.. s13 det.. modded cams + pullys. running a T3
ive had sooo many variations
cheers
Old 11-06-2007, 22:35
Over 300bhp should be possible on 18-20psi, but its only safe if the mapping is good.
What cams do you have, what exact turbo etc?
Old 11-06-2007, 22:42
rob turbo's Avatar
T3 derriced from a cossie, tomie cams.. a tad wild, quite lumpy. the bottom end has gone, bent a rod.. standard ecu with chip to run more fuel.
Old 11-06-2007, 23:04
Who's chip was it? What pistons and rods did it have?
Old 13-06-2007, 20:15
rob turbo's Avatar
custom chip, forged rodes + pistons. just a meltdown realy, think too much nos.
dont know if am gunna make it to the show
Old 13-06-2007, 22:07
Any pics of the broken bits?
Its not the psi that will kill the engine.the boost level you end up with will just be what it has to be to match your fueling limits. Its just detonation or Rpm that will casue the damage. Either that or the engine already had a fault. 300hp shouldnt be a problem on a healthy standard engine. With a good map and safe rpm limit it will last. 330ishHP has been run on the standard engine many times with the horsham developments chip and spec setup.
Good luck in your quest for a new drop in unit.Sxoc classifieds is your best option admitedly
