Old 12-06-2007, 14:38
ChEsTeR ChEsTeR is offline
Default s12 Air drag.
Does any one know what is the s12 Cx nad frontal area.
I have a piggy back computer ecumater (polish copy of smt6 but a bit improoved) and it hava a an onborad dyno, besides that it can alter the AFM or MAP output voltage with two corection maps temerature, knock or what ever, lounch control, and it can retard( for now) both ignition signals in a twin spark silvia.
Old 12-06-2007, 14:48
i think its around 0.34. yeah just checked it is 0.34.
Old 12-06-2007, 15:02
there is rolling resistance to consider as well
Old 12-06-2007, 16:11
The roling resistance and and transmition loses can also be imputed. I have print out from my las dyno and it shows haw much HP it looses at certen rmps. It will not be as acurate as a normal dyno du to changable wind and weight of the car but it can show at leest a general number and the graps of the torque and HP.
Old 12-06-2007, 18:40
shifter shifter is offline
S12oc Newbie
shifter is an unknown quantity at this point
the smt6 isn't a piggyback system. and aren't you meaning the ecumaster???
Old 12-06-2007, 20:09
Perfect power SMT6 IS a piggyback competer ( i had one instaled in my old car ) and yes i meant ecumaster
Old 16-06-2007, 23:00
Ok i tested the mobile dyno today. If the data i imputed is corect i have 210 hp and 280 Nm.
Sound about right for a ca18et with a T28 at 1 bar of boost.
And the dyno showed knocking problems due to changed ignition by changind the AFM output voltage.
