Old 19-06-2007, 23:42
mr_turbo's Avatar
mr_turbo mr_turbo is offline
Default Clutch
hey put my s13 clutch in today went in a treat runs fine took it out for a drive tonite and the pedal went low so i thought arh needs bleedin ill go home n bleed it so limpd back to my mates and started to bleed it then i notice the clucth cylinder was pi$$ing out with fluid so not hapy buni had to drive hom ewith no clutch grrrrr
Old 19-06-2007, 23:48
Hopefully you havnt made a big error with your release bearing arm/release bearing and made the slave cylinder piston pop out...
Slave cylinder push rod to release arm play should be about 3mm
It could be a nasty coincidence i suppose
Old 20-06-2007, 18:40
mr_turbo's Avatar
the seals where fuked i luckerly got hold of a s13 1 which is slightly shorter in length but has got me outa trouble tonite ive ordered 1 shud turn up tomoz had to get my mate po take me to work on his low loader how embraracing lol
Old 20-06-2007, 21:40
ChEsTeR ChEsTeR is offline
Is puting s13 clutch any better.
The dimentions are the same.
What is better in s13 then s12.
Old 20-06-2007, 23:49
S13 had 550kg pressure plate compared to 450kg on S12
Old 21-06-2007, 07:44
mr_turbo's Avatar
i was advised by alot of people to put the s13 clutch in as it iss able to take more bhp n still have a nice life! i obv wasnt 100% that it fited as no 1 cud tell me they had done it but yes it fits a treat n grips veru well so far
Old 21-06-2007, 10:13
Yeah its a good clutch that the S12 engine will probably never be powerful enough to slip.
Old 21-06-2007, 10:56
Which preasure plate shoud i use ( wich year there are two) and which preasure bearing? Should i use s12 or s13 and which one??? Im changing the cluch this weekend because mine is sliping during gear change. Last tim it slipet when i changed from 1-st to 2-nd and 6K rmp
Old 22-06-2007, 23:30
mr_turbo's Avatar
i used the clutch from a 1989-1992 200sx turbo n used the pressure plate from it as well! the release bearing also fits obv jst need to press it on deff a gd upgrade thou feels so much faster now
Old 23-06-2007, 00:35
I have bought an excedy disc and NKK preasure plate. I hope that exedy is any good because in my friends s13 it sliped at 280 HP
