Old 21-06-2007, 12:32
Default manifold to turbo gasket
I have just blown the manifold to turbo gasket, and am using a standard manifold with a t3 turbo. will a standard gasket be ok to use, or would i be better off making a copper gasket myself?
Old 21-06-2007, 13:06
A t2 gasket won't fit.
I never ran a gasket when I was using a T3. The cossie's never used them either
Old 21-06-2007, 14:27
ok, so would that just be a case of removing the remaining gasket and bolting it back up then?
Old 21-06-2007, 14:31
Yeah can do. I'm sure you can get them made up, I never looked into it as mine never blew.
Old 21-06-2007, 16:22
ok, ill try it gasketless tonite then
cheers
Old 25-06-2007, 14:17
worked a treat, cheers guys
