Old 29-06-2007, 13:00
mr_turbo's Avatar
mr_turbo mr_turbo is offline
Default What power am i runing
Hey jst wondered if anyone knows wot sort of power i am running i have the following mods! full 2 n half stainless, induction kit, t28 turbo running 10psi, i gas flowed the eshaust manifold and knocked out the walls that seperate the manifold into the turbo! a ball park figure would b nice and wot is the standard power fanx
Old 29-06-2007, 14:20
Standard power is about 135 and on that setup you should see about 170-180.... just a fairly uneducated guess though
Old 29-06-2007, 16:56
without an intercooler about 160. you need one ASAP, you WILL melt the engine if you dont get one
Old 29-06-2007, 18:42
As above.
Old 30-06-2007, 10:22
s12Rob's Avatar
s12Rob s12Rob is offline
ive tryed telling him,lol good effort m8 keep up the good work
Old 30-06-2007, 16:05
mr_turbo's Avatar
i know hents y im onli running low boost! i gettin intercooler on this week n uprated pump next what shud i look at next thou??
Old 01-07-2007, 18:27
Fluffy dice
Old 01-07-2007, 19:13
what power do you want?. fluffy dice a worth 5bhp.
Edit* Looks like Jackiefans already made that sugestion.
Old 01-07-2007, 21:40
mr_turbo's Avatar
well went out brought 10 fluffy die's hoping the extra 50bhp helps cnt feel a difference atm do i have to hang them a certain way?
i want 200bhp+ min i had a mr2 turbo b4 n atm this still not fast enuff!!
Old 01-07-2007, 23:32
200 should be attainable with the modifications you have fitted once you have an intercooler fitted and do another mild boost hike to around 12psi
You could see more 230+ish if you fit a safc(or any other remap method) piggyback ecu with s13 injectors and boost at around 17 psi
you need to connect a diode to each dice and then join up the diodes, This way they work properly with the s12/
Im selling some diodes in classifieds if your interested
