Old 09-07-2007, 17:01
mr_turbo's Avatar
mr_turbo mr_turbo is offline
Default headgasket
i want a uprated headgasket is there any tuners who do them ?? or is it not worth uprating it?
Old 09-07-2007, 17:29
badboy's Avatar
badboy badboy is offline
badboy is an unknown quantity at this point
ive just fitted a stock one on mine following advice and it certain seems ok after the weekends abuse, are u gona be running a lot of boost
Old 09-07-2007, 18:56
mr_turbo's Avatar
well i wana run a bar once ic on n full pump etc the turbo more then caperble jst worried about headgasket! do u know wot plugs i shud be running wid my setup atm>
Old 09-07-2007, 19:04
providing your head hasnt been skimmed too much a NISSAN headgasket will be fine. Patent ones are 99% SHIT
Old 09-07-2007, 19:05
mr_turbo's Avatar
lol ok to nissan i go then lol
Old 09-07-2007, 20:50
badboy's Avatar
i run bcr8es ngk plugs but not sure if there a bit cold for road use, are you having problems with plugs at the mo
Old 09-07-2007, 21:02
http://www.nissansilvia.co.uk/vbb/showthread.php?t=463
Old 09-07-2007, 21:21
i think cometic do metal head gaskets for the s12, they are only 100 quid and come in a range of thicknesses. try apex performance as they deal in them.
They are widely used on the s13 and as far as i know no one has had a fault with one, and hopefully enough mine will be ok to lol
