Old 13-08-2007, 21:50
Beany-s12's Avatar
Default low oil pressure
my gauge sits bouy 1/3 up from cold! the hotter it gets, the lower it gets! if u really thrash it, it drops down to zero
the sender is only bout a year old and genuine nissan i think!
just wondering if the pick up filters tend to get blocked in the sump as seen a few ca18det lumps which have suffered from this!
Old 13-08-2007, 21:56
dont trust it, the standard one usually is fubar. Try a mechanical one to be sure
Old 13-08-2007, 22:34
what oil and oil filter are you using?
Old 13-08-2007, 22:40
Beany-s12's Avatar
10/40 semi synthetic oil with fram filter
Old 14-08-2007, 20:50
smoker's Avatar
smoker smoker is offline
mine went about half way then dropped back to 1/3 before rebuild, now it goes 3/4 cold and just under 1/2 when really hot. Think it was just general wear in crank shells and leaking turbo seals but never made any knocking noises.
I would think that a 10w-50 oil would be better at maintaining hot oil pressure than 10w-40
Old 14-08-2007, 21:52
Beany-s12's Avatar
yeah but 10/40 is cheaper and she leaks from the turbo return, and turbo seals r a bit on the shite side
