Old 15-08-2007, 19:08
Dazz Dazz is offline
Default Brake upgrade.
Another 'probably' stupid question.
From the nissan range, are there any models that have a 2 pot or better calipers that i can swap over to my s12?
Or are there any other cars that i can rob some proper stoppers from?
Im looking for a fairly easy upgrade, i dont mind minor fabrication, just not a full on rebuild.
Thanks Dazz.
Old 15-08-2007, 19:36
323ian 323ian is offline
Remember the master cylinder to brake caliper piston ratios have to remain the same as stock if not you will get crap brake 'feel', its not always just bigger is better.
Old 15-08-2007, 20:24
S14 4 pots do the job...
http://www.nissansilvia.co.uk/vbb/sh...highlight=pots
Old 16-08-2007, 12:45
Thank you! Now off to the Breakers.
Old 16-08-2007, 13:27
No pun intended i guess
