Old 29-01-2006, 18:38
Default grooved discs
what discs do you lads recomend for the s12, i think martin has tried ,SE items and black diamond, rob turbo has roto discs on i think, any feed back would be good as i'am going to be putting my s14 calipers on as soon as my hoses arrive.
Old 29-01-2006, 22:14
Magnum's Avatar
Magnum Magnum is offline
12.2 inch (310mm)diameter vented rotors, with BILLET aluminum center , BILLET aluminum 4-piston calipers (stainless steel pistons),
aluminum caliper brackets , and all mounting hardware and stainless braided lines .
Old 29-01-2006, 22:49
Dan how much was that set up ?
Old 29-01-2006, 23:25
Magnum's Avatar
$750US (424.038 GBP United Kingdom Pounds)
Old 29-01-2006, 23:30
thats a bargin in my reckoning
Old 31-01-2006, 13:37
do they bolt straight on to the s12 struts with no fab??
i have had a bad experience with rotor discs, had a set of my honda accord and they cracked all the way through on both discs.......
Old 31-01-2006, 17:48
Magnum's Avatar
Yes strait bolt on. Were your Honda rotors cross drilled? If so thats why they cracked.
Old 03-02-2006, 16:04
i dont think they were cross drilled, where did you get the wilwood brake kits from??
Old 03-02-2006, 17:39
Magnum's Avatar
http://www.arizonazcar.com/510brakes.html I haven't purchased them yet because I have to send him a strut and hub to make sure the S12 front strut and hub is exactly the same as the S130, which I'm sure it is. They also have a 13" (330mm) Big brake kit aswell for 564.998 GBP United Kingdom Pounds with optional 6 piston Calipers for extra that would be 766.616 GBP United Kingdom Pounds for the 13" rotor with 6 piston calipers.
Old 03-02-2006, 18:38
yea cool let us know what happens with them plz, would be interested in a set for me self
