Old 22-09-2007, 10:47
mr_turbo's Avatar
mr_turbo mr_turbo is offline
Default Intercooler
i now have my front mount on and cor dioes it make a difference in performance i was well impressed!!! and i now get huge amounts of turbo chatter! im runin 11psi with full exhuast indutcion kit t28 gas fowed manifold n fmic whats the max boost i can run?
Old 22-09-2007, 11:00
you would need to put it on a dyno to find that out.
i wouldnt take the boost any higher until then
Old 23-09-2007, 14:08
Oscar's Avatar
Oscar Oscar is offline
or you could do wat i did with mine lol.............turn it up as high as i cud and see how long it lasts......... about 20mins reading 16psi lol
Old 23-09-2007, 15:03
nots13 nots13 is offline
nots13 is an unknown quantity at this point
i hope you haven't ruined my auntie silvia ya cruel bugger
1991 Lexus Soarer twin turbo....320 lb/ft from 12psi of boost!! bye bye m3
Old 23-09-2007, 23:18
mr_turbo's Avatar
hmm so if i run it at a bar it not safe then?
Old 24-09-2007, 00:22
Beany-s12's Avatar
i've been running a bar on a t25 for a few months now! u can really feal it struggle after bout 4500rpm in 3rd 4th and 5th like it desperatly needs more petrol ! would knock it down to bout 12psi if i could but it seems like thats the lowest the actuator will let me! oh and think it might die soon ! got 2 spare engines so who cares
Old 24-09-2007, 16:44
mr_turbo's Avatar
well this was the problem i thought i would encounter soooooo im gettin a cold injecter from a scrapys n weldin it to my boost pipe on the inlet and using a pressure switch set to 8psi to actervate it hents after 8psi it will inject extra fuel solving that problem
Old 24-09-2007, 16:48
5th injectors suuuuuuuck fancy trying out a chip for bigger (s13) injectors? you'll have to check your ECU is the right type by opening it up and showing me a picture
Old 24-09-2007, 19:27
mr_turbo's Avatar
hmm maybe yer!!!
all you need is a picture of my ecu internals?
Old 24-09-2007, 20:09
Oscar's Avatar
sorry to say nots13 the silvia is very dead......... she went well tho..... screaming to the end......... rad went then got replaced then boost killed it and there was that much rust underneithe it wen i stripped it down
