Old 01-02-2006, 15:08
Default sr 20
do sr20's in s14's run with a distributorless ignition system, coz my pulsar engine although in a different state of stanard tune runs with a dizzy cap, i was just wondering because if i do go rear drive there might be some clearance issues with the firewall , as the distributor is on the back of the engine, i suppose i could always muller back the firewall with a large correcting stick
Old 01-02-2006, 15:41
I don't think the Pulsar SR's mount up to the S14 gearbox...
Old 01-02-2006, 16:38
why's that then ? if not i could try an s 15 unit
Old 01-02-2006, 16:54
the sr20's usually seem to sit right at the bulkhead(looking at a mates 180sx) so i dont think beating the bulkhead would be much of a option?
Old 01-02-2006, 16:59
I hear the bolt pattern is different for the gearbox..
Old 01-02-2006, 17:18
i thought that they sat pretty close to the firewall , i suppose i could always cut it out and weld some sort of boxy type thing to gain some clearance(like they do on old mini's when fitting webbers, as far as the gearbox go's the only difference that i know between pulsar sr20's and s14 ones is the block construction in that the pulsar block is all alloy , i can't see why they would cast a different block for just one engine type surely it would'nt be cost effective, but then again i could be wrong
Old 01-02-2006, 17:23
i had a ca18et engine from a silvia and tried to put it in my ca18et bluebird(fwd) and only about 3 of the gearbox bolts lined up
Old 01-02-2006, 17:32
if the worst comes to the worst i could always get a bell housing adapter made up , but i'm gonna try and cram in all the 4wd stuff in there if i can, at the moment i'm just exploring all of my different options
Old 01-02-2006, 18:06
The SR20 will only fit in a car with the original drive configuration that it came out of due to engine mounts and gearbox. A GTI R eninge will not go in a Primera even though they are both transverse mounted because of the 4 wheel drive transfer box and gearbox, and the engine mounts are different on both from the rear wheel drive SR20.
Old 01-02-2006, 18:20
sounds like some major silvia surgery comeing up then
