Old 14-10-2007, 08:59
Rally Martin Rally Martin is offline
Rally Martin is an unknown quantity at this point
Default Wil s13 shafts fitt s12?
I HAVE to use s13 flages on my LSD. I cant modify the s12 flanges this time. the the s12 shafts will not fitt on an Nismo LSD whatever you do!
So i have to make some mods to make this work.
Will s13 axles work if i use s13 inner flages, and s12 outer flanges?
I found a pic on this forum. And it looks like someone are using s13 axsle on the right side! And if so, then it shold be able to use it on the left side to, only 8mm lenght differense on the s12.
http://img.photobucket.com/albums/v2...i/DSCN9600.jpg
FJ20 POWER
Old 14-10-2007, 17:11
I made that diff in the picture.
Both those shafts are the shorter passenger shafts. To use the S13 inner flange on the long side you use the shorter shaft, but on the passenger side you will find the short shaft still too long with the S13 flange so it will need shortening professionally
Old 14-10-2007, 17:43
Are both your shafts from s12?
The axles in the pic, are they s13 or s12?
Om my shafts the inner part is sealed together with the axle. I dont have flanges in both ends, like the axle to the right on your pic.
The only difference in lenght on my shafts in 8mm, right side shortest..
Thanks
FJ20 POWER
Old 14-10-2007, 18:44
Thanks
No the left side is the shortest
FJ20 POWER
Old 14-10-2007, 18:54
Both of those are 2 left hand short shafts.
One is normal, but the other has the S13 inner part.
Old 14-10-2007, 19:00
Okay.. Thanks
But my shafts dont have two flanges, so I cant use any of them. Mine is like this : (hope its okay that I use your pics, 30psi )
http://www.datman.co.uk/f/cvshafts.jpg
FJ20 POWER
