Old 07-11-2007, 20:05
Dazz Dazz is offline
Default S12 aftermarket wheel question.
i know the S12 pcd is 4x114 and et 35-42, but will 4x114.3 wheels fit, as i know where a cheap set of the Integra Type-R enkies but im not sure iff the .3 makes much difference.
Dazz
Old 07-11-2007, 20:27
bigtim's Avatar
bigtim bigtim is offline
s12's are 114.3 are they not
Old 07-11-2007, 20:45
RichardK's Avatar
RichardK RichardK is offline
Forum Administrator
Yes, S12 wheels are 114.3
Old 07-11-2007, 20:49
114.3 they are
Old 07-11-2007, 20:54
So why the difference between 114 and 114.3, as i have a set of rota's on mine and they are 114.
Old 07-11-2007, 21:23
Old 07-11-2007, 22:04
zxocmars zxocmars is offline
Basic it's the translation from imperial to metric
Size is 4 * 4.5 inch, = 4 * 114.3 mm
Size just gets abbreviated to 114
Old 07-11-2007, 23:22
But there are also a true 114.00mm PCD wheels as well and these have led to issues with stress on the studs
Old 08-11-2007, 08:39
mr_turbo's Avatar
mr_turbo mr_turbo is offline
im using a 4/114 on mine fit fine it only 0.3mm there is no problem fittiong either.
if you intrested in a different set off wheels check out my work www.alloywheels.com cheapest place for wheels and tyres in uk!!!
also will sort out mebers on here even cheaper
Old 08-11-2007, 17:28
Oscar's Avatar
Oscar Oscar is offline
so honda 4 stud rims fit.......... hmm me has a plan
