Old 08-11-2007, 17:26
Oscar's Avatar
Oscar Oscar is offline
Default interchangeable parts
bin wondering today, wat parts are interchangeable thru the family, ie s12/13/14/a, tho i doubt any s15/14 parts will,
any one used any parts apart from the obvious like the det or diff,
cos with the last silvia i owned we tried to measure up for a shortened s15 underpinings on a silvia shell, but it went to pot llol
Old 08-11-2007, 23:10
mr_turbo's Avatar
mr_turbo mr_turbo is offline
s13 clutch and most bottom end parts are i think
if you have the tools n know how you can make anything fit
Old 12-11-2007, 14:03
terry terry is offline
terry is an unknown quantity at this point
s13 coilovers, you can even use the rear ones if your andy with a welder, its not too hard to build new towers, just takes balls to make that first cut and realise theres no going back.
Ill let you know if an s14 dash fits when i find one cheap
Old 12-11-2007, 18:40
Oscar's Avatar
sounds good, should spruse up the interior nicely
Old 12-11-2007, 19:56
old-and-rusty's Avatar
I would be interested to know if the dash fits too .
I was planning on getting an s13 donor car, when I change my s12 from an auto to a manual, so I thought I would try the s13 dash for size then. But an s14 dash sounds even better .
Regards,
Ian.
