Old 15-11-2007, 19:19
mr_turbo's Avatar
mr_turbo mr_turbo is offline
Default Hybrid Turbo
has anyone ever had a turbo hybrided or got 1? mine started to make a very slight wining sound so im going send it off to get rebuilt n hybrided!hehe any excuse!
found a few places best quote was £270 and they rebuild mine not an exchange!
Old 15-11-2007, 20:56
i had my first T2 made to the fullest hybrid they would go, came on boost at just over 1800 RPM also 360deg bearing, not sure what they did to it, but i had full boost long before the std one i have atm, full boost now is about 3000, this hybrid was full boost long before 2500 and spooled up fast too.
sadly i treated it bad, and it has bout 2mm up and down play, and 3mm in and out. im waiting on saving up to get my T25 done, but i also need to make a new downpipe part for the exhaust to fit it to my stainless elbow.
Old 15-11-2007, 20:59
I had one. Im not sure what happened to it. Adz had it for a bit. Maybe he sold it to someone on here. It worked very well and took lots of abuse without fail. But in the big picture of things it was shit. Size matters
Old 15-11-2007, 21:09
for fook sake, don't try and rebuild your own turbo's like adz did, they need rebuilding properly, if the turbo goes tits up, then your engine could goe the same way as well, tbh i wun't bother with anything under a t28, the lag ain't that bad ,my t34 came on at about 3200rpm.
Old 16-11-2007, 18:40
mr_turbo's Avatar
mines spoils aroiund 3000-3500 bit laggy at times but worth the punch all day long just need it rebuilt and not going to pay out for it to be the same as it is might aswell increase the power slighty
HYBRID it is then!!!!
Old 16-11-2007, 18:43
3500 rpm is a bit laggy for a T2 (which I assume you're using?). My T3 was 4,000rpm.
I have a nice turbo here which I need to get round to fitting. Its a T28 from a pulsar with a T3 compressor housing.
