Old 23-11-2007, 07:43
mr_turbo's Avatar
mr_turbo mr_turbo is offline
Default spacer kit
i fited my 20mm spacer kit yesterday had to replace the studs with extended ones but makes the rear wheels look better ill get some pics up later was wondering how much other people have spaced teres by as there is enough room to still go another 10mm withouit rolling the arches
Old 23-11-2007, 10:25
Where did you get the spacers/studs from?
If the chosen wheels had the correct offset in the first place then you shouldn't really need spacers, but normally most typical 17's are around ET35-42
Old 23-11-2007, 12:15
mr_turbo's Avatar
yer the wheels are the right offset there 35offset i work for alloywheels.com
where the car is 100mm lowered the camber is major and the top of the wheel was siting in a bit to o far for my liking thats the only reason i put them on the top is now 1/4 inch from the arch and the bottem sits just outside.
i got the studs from select. and our company deals alot with wolfrace so had some spacers siting around the workshop!
Old 23-11-2007, 12:27
Are you able to tell me the price of the studs?
Yeah true, the camber does impact the space between the wheel and the arch. Put the standard springs back in and make it look like a 4WD car lol
Old 23-11-2007, 16:48
mr_turbo's Avatar
yer £14 ish for 8 inc vat!
yer i know if i fancy a bit of offroading ill throw them back in lol
Old 10-02-2008, 12:48
James H's Avatar
James H James H is offline
Hey i am after a set of wheels spacers don't spose anyone got a set of bolt of spacers laying around that they want to sell, if not anyone know where i can get a set for a good price, many thanks?
