Old 13-12-2007, 16:45
Dazz Dazz is offline
Default Intercooler and dump valve fitted.
Hi guys, i did a search and found a few bits of advice but i just want to check a few things.
Ive just finished fitting my intercooler to the S12 with a T2, i used a Golf 20v turbo wing mount and mounted it by the rad with a good cold air feed, i used a cosworth 2inch - 2.5inch boost hose from the turbo to a 2.5inch tube around 6inches long then to a bit of silicone coupling to the bottem of the cooler, from the top outlet of the cooler i managed to use the standard hard pipe with a 2.5inch T-piece for a bailey dv26 dumpvalve then fitted to the throttle bodie, for the dv vac line i plumbed it in using the black vac pipe that runs across the top of the bulk head under the vin plate? i assume thats ok as i read most use the one from the fuel reg.
I also fitted a boost controller, mechanical one its a ball type or something, and i just set it half way, so im unsure of the psi, now the car drives great, i seam to have really strong top end power, strange as but if i drive hard the wheels spin all the way to the redline where as befour it wasnt as strong and the power dropped off a little earlier, the dump valve lets off buts not really that loud, so do you recommend i bin it? as i seam to have lost the chatter noise from the waste gate.
Thanks and sorry for the essay, just thought the more info the better.
Dazz
Old 13-12-2007, 17:00
i really think dump valves are not needed unless you are running very high boost, they stop the turbo stalling and twisting the shaft, they also cause uneven idle and a moment of overfueling on a car with and air flow meter.
Old 13-12-2007, 17:12
Oscar's Avatar
Oscar Oscar is offline
ive found in the past, that the nearer to the inlet the louder they are post up a pic of the intercooler matey
Old 13-12-2007, 17:42
I'll post a pic when theres some daylight, i think the DV is a twin piston? maybe a bit stiff, worked fine on the evo but i was running 1.6bar, so im guessing the baby t2 doesnt push that much.
Thanks
Old 13-12-2007, 20:29
mines a bailey twin piston dump valve, and tbh my T2 dont make it sound as loud as it prolly would with a T25
Old 14-12-2007, 18:06
Hi again, no pics yet, but i tried a forge dump valve from a friends RST and its alot louder, so i assume that the spring is weaker on the piston, not really worried about the DV so i think i'll run without.
Old 14-12-2007, 18:31
the cheap xs power dump valves are better than bailey and forge imho, it took 32psi on the t34 before the xs power dump valve started to leak, just needs a stronger spring and you can take the xs power ones apart easy enough, i used a bailey first ,but it leaked, they ex power do singlke and twin trumpet and my single is very load, i will use it, although the sxoc seem to be against them and say they are ,but i'd rather protect the turbo, there although there will be nothing about 600bhp.
Old 14-12-2007, 19:03
Oscar's Avatar
how much did u pay for the xs power one?
Old 14-12-2007, 19:12
about £60, but i think they are even cheaper now.
Old 15-12-2007, 18:46
There seams to be alot of hate for XS Power gear on th MLR but i think that most of the stuff is alright, will look out for a XS DV, thanks for the help.
And yes theres certainly nowt gay about 600bhp!
