Old 26-12-2007, 21:32
Default nissan primera help
The ABS light has come on the trusty Nissan diesel, does anyone know if they have a fault reader built in or some way of telling whats wrong with out getting slapped at a garage? the MOT is up early Jan so need to get it fixed
its a w11 1999 8v diesel
Old 26-12-2007, 23:34
Beany-s12's Avatar
does the brake pedal judder sometimes like the abs is kicking in for no reason?
i've had a few primera's with cracked abs rings on the cv joint! if it is that then that'd be the symptom!
Old 27-12-2007, 01:40
bigtim's Avatar
bigtim bigtim is offline
take the bulb out for mot till you sort it
Old 27-12-2007, 02:28
Beany-s12's Avatar
if abs is fitted the light has to work! otherwise it'll still fail
Old 27-12-2007, 18:35
Oscar's Avatar
Oscar Oscar is offline
i had a gt earlier in the year, mine had same thing turned out the sensor had got coverd in shit so scrubbed it off and it was fine......
Old 28-12-2007, 01:02
I hate primera's and every owner so far. Not including you
remove and clean the sensors and wire brush the trigger wheels
