Old 25-03-2008, 15:46
ov_lozza ov_lozza is offline
ov_lozza has a little shameless behaviour in the past
Default Need more S12 help!
Posting this on here in the hope someone might reply before i get the chance to speak to Ant.
Ok, got another alternator for my S12 and the connectors are wrong
Basically what i want to know is has anybody else had this problem when finding an alternator for an s12 and is there someway of a. knowing this is the correct alternator and b. how can i change/bodge the connectors together?
Pics.....
This is the alternator im trying to fit and you can see the connectors are sort of hidden in the unit, whereas in the next picture you can see the connector on the car is meant to plug into something i.e not that hole on the alternator.
*Sorry for the lame ass explaination.
Old 25-03-2008, 16:11
the mk1 uses the same connector as that, i've had to swap them over before.
Old 25-03-2008, 16:13
Any tips on how? Would be much appreciated.
Old 25-03-2008, 16:19
i'll check my spare harness but i think its a mk2 harness, your harness looks like a mk2, only trouble is i think i need that connector as well, but i think i already chopped it out and left it on the mk1, i'll check in a min, other than that you will pick a connector like that up from the scrappy on some old nissan, or there maybe someone on hear with an s12 breaking.
Old 25-03-2008, 16:26
ok, disconnect your water bottle pump connectors, and try them into the socket they look the same, if they are i have 2 spare.
Old 25-03-2008, 16:33
Oh ok! I will do that asap! Ta!!
Old 25-03-2008, 16:51
ok after looking, i think its the wrong size, but look at this, its a small relay that i think has the same connector.
the smaller one looks right, theres a small relay in your engine bay, check it with that.
Old 25-03-2008, 17:02
It looks similar to the one on the left there!
Here's a pic...
I couldn't try and fit it into the alternator but it looks like it will fit perfectly!
So if you have a spare one that'd be great, i'll drop you a PM if you have.
Old 25-03-2008, 17:04
ok no probs, i'll send you both just in case, because i'am thinking its the smaller one that will fit.
Old 25-03-2008, 17:06
you have PM
