Old 13-02-2006, 11:00
Default Part numers from nissan
This thread is an excellent idea by Adz. Please can we only reply/add to it with more parts & numbers? Rich.
All prices excluding vat
Head gasket set £107.27: A104207F2E
Turbo gasket £16.48: 1444526E00
Inlet maifold gasket £8.41: 14035-D5700
Exhaust manifold gasket £4.17 each :14036-02E00
Ehaust manifold studs £1.15 each : 08261-03010
Exhaust manifold nuts £0.94p each : 08912-84010
Timing belt £24.10p : 13028-D0185
Rear subframe bushes £42.05 each : 55466-04F10
Crank woodruff key £1.17p each : 00926-51900
Crankshaft oil seal £3.50p each : 13510-88G00
Camshaft oil seal £4.30p each : 13042-D0101
Water pump gasket £3.12p each : 21014-D5701
Rear spring cup rubbers £10.20p each : 55038-01P00
Rear Arm to Subframe Inside Bolts (flat side on thread) £8.71 each: 55216
Front (R) arm (bracket tension plate) (has bush and ball joint) - 54480-01F00
Feel free to add anymore
Old 15-05-2007, 20:31
eurolightning eurolightning is offline
eurolightning is an unknown quantity at this point
heres the part numbers for rear wheel bearings (for a MK11 now i know lol) these are all single's so if your ordering check with the dealer you have order the right amount to do the job
43215 F6100 bearing
43210 21000 bearing
43070 01P00 SPACER
43232 F6100 OIL SEALS
Old 15-05-2007, 22:35
Originally Posted by eurolightning View Post
heres the part numbers for rear wheel bearings these are all single's so if your ordering check with the dealer you have order the right amount to do the job
43215 F6100 bearing
43210 21000 bearing
43070 01P00 SPACER
MKI or MKII as they are different!
Old 15-05-2007, 23:00
Ok i asked about an 1988 dose that help clarify the MK
Old 15-05-2007, 23:44
Mk2 then
Old 15-05-2007, 23:46
Cheers
the post now edited
Old 27-02-2009, 19:12
Default colour 123 bluish grey met
KE998-12325AA in touch up/spray can
NO LONGER AVAILABLE
have to get one made up now
Old 28-02-2009, 16:04
There was a bloke on ebay selling Nissan touch up paint a while back don't know of he still is and if he's got any but worth a look.
Old 28-02-2009, 19:41
Tried them all matey cant get them!
Old 02-04-2009, 15:06
an update on a couple of prices -
Ehaust manifold studs £1.15 each : 08261-03010 - now £1.42 each
Exhaust manifold nuts £0.94p each : 08912-84010 - now £1.16 each
