Old 12-05-2008, 00:16
irish s12's Avatar
Default which lsd to buy?
does anybody know is it possible to buy an off the shelf lsd that will fit straight into an s12 without loads of mods?
Old 12-05-2008, 10:05
Nothings been confirmed as far as I know but I think S13 LSD's for the Pre-facelift model should work with minimal modifications and I'm pretty sure someone is running an S14 diff, again, with limited mods/scavenging required.
I've been trying to get hold of some output shafts to compare them with standard S12 ones, but no one's been willing to part with any when I've asked around
Old 12-05-2008, 18:20
chrismisk's Avatar
chrismisk chrismisk is offline
chrismisk is an unknown quantity at this point
I think an s13 one should because my s12 came with s13 driveshafts on it
Old 12-05-2008, 18:57
Arn't S13 driveshafts are to long? Might have the S13 output shafts and S13 CV joints on S12 shafts though, that's not a huge amount of work and is what I was trying to look into but couldn't find any output shafts
Old 12-05-2008, 21:09
chrismisk's Avatar
Don't really no the fella i bought it off said they were s13 shafts cause he was goin 2 put a s13 lsd in it to put it on the road
Old 13-05-2008, 15:54
I doubt highly you will have S13 shafts
Old 13-05-2008, 18:27
chrismisk's Avatar
Yea i really don't know i'm just goin on what i was told when i bought the car and wouldn't know enough about them to say any different
Old 14-05-2008, 22:27
duncan's Avatar
duncan duncan is offline
s14 diff fits handy enough into s12 casing. just swap crown wheel and put back in. shafts are another story. theres one s12 shaft shorter than the other. can't remember which side it is though. anyway you need 2 short s12 shafts s13/14 diff and inner drives. the left hand s12 shaft needs to be shortened to avoid shuddering. little time comsuming but worth it if you want a bit of sideways action
Old 14-05-2008, 23:31
Someone tried fitting an S14a diff and found the shafts to be thicker. So therefore they couldn't grind the S12 shaft shorter as it didn't have the required girth.
Old 15-05-2008, 01:37
irish s12's Avatar
i've read somewhere that an s15 helical will fit if you have the six bolt output shafts.Has nobody tried fitting 1?I've had enough of spinning 1 wheel!
