Old 14-05-2008, 14:51
Default Wiring help car alarm
I bought an alarm/immobiliser ages ago and having got my Silvia MOT'd today, I'm trying to fit it.
Basically the only diagram I have is on the back of the control until. I am stumped by what to wire the Three Yellow wires into the ignition. The other is the 1ch 2ch 3ch 4ch wires. I gather these are accessory wires. Any ideas I would be brateful
http://www.saturnfans.com/photos/sho...23/ppuser/4834
Old 15-05-2008, 12:59
old-and-rusty's Avatar
I`m not 100% certain, but I think you could wire a flashing led into part of the accessory ch wiring. Sorry I can`t help on the ignition feed, the last alarm I did was supplied from the fusebox not the ignition.
Regards,
Ian.
Old 15-05-2008, 19:22
that diagram is pretty poor as it does not present the nescessary information, it leaves you to puzzle a few things out.. however assuming that "square" where the three yellow wires congregate is a relay then this forms a crude immobiliser system. the yellow wire for the "ignition key switch" hijacks the output from the ignition barrell for the IGN position. Then replace the coils +12v feed with the thick yellow wire labelled ignition coil. the thin yellow wire goes to the ACC output of the ignition barrell.
Picturebook edition with lift-up-flaps on request
Old 21-05-2008, 18:49
its all done and fitted. Now fitting a CL kit and full closure module. Anyone else fitted and alarm to a silvia ?
