Old 12-07-2008, 15:47
Default Non starter
I've been away for a few months and before I went my Silvia was running ok one day and the next it refused to start. Over the past 8 days when I've had time I've checked everything fuel and fuel pressure, I have four good sparks, I've changed the injectors, the MAF, put on a new coil and reset the timing and the bugger still won't start and I've run out of ideas so any ideas are welcome.
I may not reply for a few weeks or so as I have to go away again for work next week so I'll thank all who reply in advance.
Old 12-07-2008, 19:14
Is the fuel pump priming when you turn it on??? If so and you have a spark could be flooding the plugs. Try taking out the fuel pump fuse and clearing it then replacing it
Old 13-07-2008, 17:13
Tried that as well but as there was a long enough period of time for the fuel to evaporate when trying to start plus when trying to start it if it hasn't fired after a couple of seconds I've not continued to try, as I said it was running one day and wouldn't start the next I don't think this is the problem.
