Old 18-08-2008, 15:27
Default Are all S13 diffs LSD's?
I have bought a diff from a 1989 180SX will it be an LSD and how do I tell before I start taking it to bits? I read the spec list for the cars and it said they do have a viscous LSD??? HELP !
Old 18-08-2008, 15:31
usually they have a yellow sticker on them that says vlsd, they earlly s13's din't have a lsd i don't think.
Old 18-08-2008, 15:36
Default No Sticker
I can't find a sticker on it at all. Can I tell if I remove the end casing?
Old 18-08-2008, 15:39
Default Oil Cooler
It does have an oil cooler with it so this would indicate it is a vlsd????? why would you need an oil cooler on a non lsd?
Old 18-08-2008, 15:54
Try turning the shafts in opposite directions.
An LSD is almost impossible to turn in opposite directions.
Old 18-08-2008, 17:03
Default Took apart
Just took the end casing off, can turn shafts in opposite direction quite easily but why would it have an oil cooler on it and does an lsd look any different inside to a non lsd??
Old 18-08-2008, 17:18
Default Its an early one
Its off a 1989 G 180SX S13 so one of the very first ones. Any numbers anywhere to give me a clue as I am going no further if it isn't suitable.
Old 18-08-2008, 17:53
That's an open diff, if it looks like that you don't have an LSD.
Default Its off a 200sx turbo
How stupid am I , its off a 200sx 1.8 Turbo. Is it a LSD ????? HELP
Old 18-08-2008, 17:55
Default Looks like that
It looks exactly like the one in the photo, so I've just paid £80 and a round trip of 150 miles for no reason. Bugger
