Old 17-02-2006, 12:21
Blue_Neon's Avatar
Blue_Neon Blue_Neon is offline
Blue_Neon is on a distinguished road
Default Fuel Gauge question
My fuel gauge seems to go down VERY quickly, like it can move from 1/4 full to empty in 3-4 miles
I guess I have lived with it since I bought it, but am noticing it much more latley. I put £10 of gas in it (say its 10 liters or 2 ish gallons) when it appeard to be empty, the needle moved up to 1/4, I drove 30 miles not thrashing it (i rarely do) and its now registering empty.
I checked the resistance of the sender, it read 48.1 ohms, book says the following:
Float Position Resistance
Full approx 4-6 ohms
1/2 approx 30-35 ohms
Empty approx 80-90 ohms
So the needle SHOULD read approx just over the 1/4 mark with my reading of 48.1 ohms.
I am not sure what to do, is the gauge notoriously lazy? can the gauge be changed so I can test it?
Also the 'low fuel' light, I have never run the silvia out of fuel. The light comes on when i put in the key (so I know the bulb is ok!) but immediatly goes out when the car starts. I have never seen the light come on, this is possibly because the fuel gauge is so far out that I have kept it well topped up with gas, and never let it hit the low mark.
Is there a way to test the Light (sender?) is working (without running the car dry)
ANY thoughts would be great, does anyone have a spare gauge I can try?
Thanks
T
What? Where?
Old 17-02-2006, 18:48
My fuel guage light works but never lights up on low fuel either,its anoying me, i would also like to know of a fix. My guage reads ok though so they must both be separate feeds from the sender rather than the light from the guage at a guess.
Do you think you are getting good fuel economy?
Old 18-02-2006, 10:07
Blue_Neon's Avatar
Im not sure on the fuel economy Jon, I rely on the gauge so maybe thats why I have never seen the low fuel light on. I am going to run the car dry and see if it comes on
It seems this is a common thing! TBH I am noticing it now I have to watch the pennies before I just squirted it in!
Ill let u know what happens
What? Where?
