Old 01-09-2008, 17:44
Default hmm, ideas
what i thought it might be, it might not, so ill give details for others to ponder for me
week or so ago i left work, my turbo is already a little smokey fubbered seals, anyway, i turned out onto a nice straight road, planted foot and away i was, but then the was a sudden power loss, so i let got of throttle, slowed a bit, then drove careful for a bit, since then if i accelerate, once the boost goes above bout 8psi i get a noise that sounds like wind down a chimney on a windy night, also wont hold the 12psi i was set at, just about copes with 9psi, but still drops off a little, ive had a look at silicon hoses, and the "look" ok but cant be 100%, first i thought turbo had gone but a week later and its still the same, so now thinking maybe i missed a hole in the hoses, as far as i see there is no exhaust blows (i had that before, but still had boost) it only does it on boost, cant get it to do it standing still with head under bonnet revvin the nuts off it, has to be moving accelerating.
any advice on this would be appriciated, as i get married in 2 weeks and away for holiday 2 weeks later, so dont really have spare monies for an unnessasery turbo change.
cheers guys be gental.
Old 01-09-2008, 21:35
Beany-s12's Avatar
Originally Posted by umpkin View Post
cheers guys be genital.
have u checked the actuator?
Old 01-09-2008, 22:17
no, would that make that sort of noise, it dont sound like the turbo is slowing down. surley if the actuator was leaking then it would be like i was at full boost, ive not had that sound at full boost before.
but ill check it out tomorrow, cheers
Old 02-09-2008, 13:54
Just sounds like a boost leak to me.
Old 02-09-2008, 17:12
im gonna change the silicon hoses, (anyone the the diameter hose i need for the cozzie intercooler??? looks about 76mm i know the T2 one is 51mm), the only other think i can see is the intercooler has been slightly rubbing on the eleccy fan cowling, and may have rubbed through on the corner of the elbow where the BOV goes on. but when whatever it was that went, it was sudden, i would think that would be the rubbing metal that did that.
Old 02-09-2008, 18:23
is the housing cracked as this would leak off some boost
Old 02-09-2008, 18:52
surley that would blow??? dont hear any exhaust blowing noises, and no black soot anywhere, but cracking housings are common, so i will check.
