Old 30-12-2008, 20:05
silracing's Avatar
silracing silracing is offline
silracing is an unknown quantity at this point
Default help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
silbaby playing up day before mot and whont start
checked it over and fuel pump is working and sending fuel but injectors not firing and spark plugs not sparking (that sounds good) any way ecu has both lights staying on that says crank angle/dizzy cap fault but now totally lost
just wont to be back on the road again soon
any help will be greatfull
thank you ben
Old 30-12-2008, 20:17
clean the area the coil is bolted to. Corrosion = bad earth = no spark
Old 30-12-2008, 20:25
silracing's Avatar
thanks for that got a spair one from my donner and mounted it on the side of suspension turret couse other was really corrowded running out of idears now
thanks lo
Old 30-12-2008, 21:42
sounds like duff distrib to me, crank angle sensor is housed inside. swap from your donor and see iof it runs. seems that if the ecu sees a dodgy crank senso signal you get no sparks or injector pulses
Old 31-12-2008, 16:25
injector are fired after the ECU recieves a signal from the CAS. First try and take out the fuel pump fuse and after turning it over for a white put it back in again. If no joy then best bet is the CAS
Old 31-12-2008, 18:07
silracing's Avatar
Thumbs up thanks every body
its alive its alive
changed complete dizzy and started to get fuel so was crank sensor playing up but still no bang bang then had a numpty moment would help if i set it up as found out it wasnt firing at cylinder one instead it was at four hahahahahaha runs now lo get it mot ed now thanks for every ones input lo
ben
