Old 06-01-2009, 00:28
Steelballz Steelballz is offline
Steelballz is an unknown quantity at this point
Default Suspension?!?!?!
Was wondering how much effort it is to fit/be able to fit coilovers all around an S12....?can remember reading they have independant springs & shocks, so cant fit coilies without a fight LOL...
or, at that note, how much effort to fit an S13 rear subframe, to also get an LSD into it...?
Old 06-01-2009, 03:08
s13 subframe has been done, but only once that i know of, and it was major fabrication on a race car. the shock mounts are not strong enough to fit true coilovers.
LSD has been done with some shaft modifications
Old 06-01-2009, 16:38
rob turbo's Avatar
if you check ebay, there are coilovers for the S12..!
they come from oz, but sensible money
they were on a few days ago, lost the link, but keep checking.. deff saw them!
Old 07-01-2009, 10:32
http://www.club-s12.org/forums/index...howtopic=18617
Old 07-01-2009, 21:02
Ebay S12 Coilovers
Doesn't look like they allow for castor adjustment though.....?
edit: how can it be a set of 4 ? Fixed rears maybe ?
Old 07-01-2009, 21:46
Originally Posted by JackieFan View Post
title of that thread from the american brothers is front suspension, I'm thinking more about the rear, and how to fit coilies to the rear.....
Originally Posted by CamInHead View Post
Ebay S12 Coilovers
thats for 86- and mine's an 84...
Old 07-01-2009, 21:51
tractor-boy tractor-boy is offline
tractor-boy is an unknown quantity at this point
No difference
Old 07-01-2009, 22:02
Probably not worth it tbh
Old 08-01-2009, 09:44
X2 for that. For True coilovers you have to cut out the old turrets and weld in new ones with a plate to accept the top mounts, you'd then have to strengthen the trailing arm to take the added loads from the coilover unit.
Absolutely nothing wrong with shocks and springs on the rear, only problem is getting the height set to what you want, but that would be no worse than getting your spring rate matched in using Aftermarket coilovers designed to fit a different car.
Spax will build you a shock to the dimensions you want and there is a company on here that have all the measurements for the standard springs and will manufacture a set of replacements again, to your spec.
The Coilover sets you can get for the S12 are Just S13 fronts with springs and shocks on the rear, they have an adjustable perch so that you can alter the ride hight +- about 2 inches
Old 08-01-2009, 12:13
Plus a good chassis shop can tune an adjustable front to match a fixed position rear.
Just need to be careful what you buy so they will complement one another.
