Old 25-02-2009, 21:37
Default where can i get some shocks my local automotive place does'nt do them????
as the title i could do with a car set?????
Old 25-02-2009, 23:40
kyb do a gas shock set for the silvia but cant remember where i got them from tho?
Old 25-02-2009, 23:58
paulsilv on here knows a place that does them cheap.
Old 26-02-2009, 12:36
what price do they go for? i have no clue!
whats the situ with the front shocks, from the manual they are rebuildable? ie you can change the fluid & the seals are probobly available from nissan?
or can i by inserts for them?
cheers muchly
i'm filthy after lowering the rear of my car today! bought some new pads for the front & rear too
i need new disks on the front & i cant find them either? can i use s13 4stud front disks?
i like my s12 more today
Old 01-03-2009, 16:01
paulsilv's Avatar
paulsilv paulsilv is offline
Pm:d
Old 02-03-2009, 15:03
i'll giv tht place a go for the rears then!
i'm unsure on what to do on the fronts! can i fit shock inserts "the damper tube" or shall i just put fresh oil in & seals?
Old 02-03-2009, 19:44
you can get kyb inserts for the front (kyb P.no 365013), although they seem to be hard to get these days.
for the rears, you can fit mk2 escort uprated rear shocks if the car is lowered for bout £110 pair on ebay, I think kennyboy from this forum has a set on his, if its not lowered then i prolly wouldnt use them as they are shorter and help with lowered loose springs only
on a side not, if kenny reads this, did the escort shocks make much difference to handling???
Cheers.
Old 03-03-2009, 19:59
i dont know if this is true but i heard/read toyota hilux rear shocks fit???
Old 03-03-2009, 22:43
irish s12's Avatar
i have a full spare set of monroes if you want,they are gas rear and oil fronts.they have 7000miles on them and are as new.
Old 03-03-2009, 22:52
irish s12's Avatar
front discs are hard to get,the last time i got them the only people who did them were ebc.I have seen discs advertised on ebay,but i dont know if they fit.s13 discs will not fit.
