Old 24-08-2009, 09:51
Default fao 30psi
hi mart, japster (den) could do with a bit of advise, he was wondering what would be involved in fitting an s14 diff into the s12, if its possible, any help would be appreciated mate, thanks .
Old 24-08-2009, 11:44
It might be the same work as doing the S13.
But there are 2 types of S14/S14a diffs I think. If the shaft bit that actually goes in to the diff is the same thickness as the S12 then it can work.
I believe some S14 diffs have a thicker shaft though and this will mean you're fcuked as you won't be able to use the reground S12 shaft
Old 24-08-2009, 18:42
cheers mart.
