Old 18-03-2010, 18:32
londonsilvia londonsilvia is offline
londonsilvia is an unknown quantity at this point
Default Smell of petrol coming from boot?
ive been told that the smell of petrol in my silvia is due to the boot or rear seals condition or that there is a hole somewhere. i can only smell petrol when i open the windows or the roof and its not coming from the engine bay.
has anyone had this problem?
Old 18-03-2010, 20:10
could be the pipe from the filler cap to the tank, if it is i have a spare.
Old 18-03-2010, 20:53
it smells like its burnt fuel, not fresh.
my fuel pump is whining a little too.
Old 19-03-2010, 10:39
if it is this filler thing, how do i check?
Old 19-03-2010, 11:33
chewingtobaco's Avatar
chewingtobaco chewingtobaco is offline
chewingtobaco is an unknown quantity at this point
you may have a hole in your exhaust or a loose flange on pipe bud?
Old 19-03-2010, 12:54
yeah probs a blowing exhaust as above
Unless youve played around with your fuel pump recently,then it could be the cradle gasket
Old 22-03-2010, 15:13
pukka - nothing has been touched since you touched it re: engine and fittings minus some twiddling with the injector plugs - they are pretty worn. i dont know what a cradle is, but the pump has been making a whining noise for a while, its gone away a little now. but its a burnt fuel smell, not a fresh petrol smell.
i was told that if the boot isnt sealed properly, when i open a window or sunroof, the fumes would be drawn through. im going to sellotape the outside and stuff some thick fabric in the boot and see if its coming from there.
the thing's so noisy, i wont be able to hear whether there's a blow!
Old 23-03-2010, 22:21
i carpeted the boot and sealed the open bits in the boot but im still getting the smell of burnt petrol. im going to check the exhaust.
Old 30-04-2010, 09:50
checked the exhaust and no leaks.
the smell only comes on boost... any other ideas?
Old 01-05-2010, 17:36
If its Burnt fuel smell then it Must be coming from the Zorst somewhere. If it is just a fuel smell it maybe the thin rubber seal around the top of the fuel pump fitting in the top of the tank
