Old 21-05-2010, 13:37
Default ca lambda thread size
Anyone know the thread size in the elbow ?
Old 21-05-2010, 13:48
M18 rings a bell, pretty sure its the same as a spark plug
edit:-
have been known to talk cobblers of course , so will see if i can find the thread tap i bought to make a lambda boss
Old 21-05-2010, 15:44
IIRC theres only 2 types of lamba sensors, and i think the det uses thin narrowband ones. tbh dont bother with it, its a waste of time and money.
Plug it up and fit a wideband sensor if you want to know your mix ratio
Old 21-05-2010, 17:43
I'm going to be running a pre lambda ecu so was wondering what thread to block the hole up. I'll try a spark plug for now instead of welding it incase I get a wide band later
