Old 12-09-2010, 17:55
Default T28 Fitting
I've got a T28 I'm going to put on the only problem I can fore see is that the outlet which bolts onto the turbo faces the bulkhead. As I'm going to plumb in the FMIC would the best way round this be to bring it round 180 or i8s there another way I've not thought of?
Old 23-09-2010, 19:50
About time you plumbed that FMIC in!
How come the turbo's pointing the wrong way? off the Sunny GTiR or something?
Old 24-09-2010, 15:14
Dave you could be right it might be off a GTI-R as it's just the outlet that's facing the wrong way.
Old 24-09-2010, 23:29
dannys12 dannys12 is offline
dannys12 is an unknown quantity at this point
sounds like a pulsar 1 as i have one on mine just loosen the 4 bolts and rotate it round thats what i did
Old 25-09-2010, 15:47
Rotating it won't make any difference as outlet bolts onto the turbo and will only bolt on one way and that's rearward so it looks like I'll be using a 180 bit of pipe or a couple of elbows with a pipe between them.
Old 25-09-2010, 19:13
what i did to make mine fit was loosen the 4 bolts on the compressor housing and rotate it round where i wanted it as it hit the manifold
